RC AIRCRAFT BUILDS Electric Powered Another STOL plane Reply To: Another STOL plane
#13468
The Draco turned up this morning so 6 days from Melbourne, delivered Door to Door wasn’t too bad.
The box looked a bit worse for wear on one edge but with all the padding the seller had placed inside, the plane was undamaged.
It went back together very easily & after spending most of the afternoon programming the Jumper T16 to talk to the $195.00 Spektrum (AR637TA) receiver fitted to it all now seems to be working.
I have full 6 channel functionality on the lights, the motor reversing works fine & I can even display the telemetry from the smart receiver so a good days work.
The Safe Select function is working but at present wont switch back to AS3X mode so I will need to look at that tomorrow.
I’ll also need to make an adaptor to connect the IC5 battery connector on the Smart ESC to an XT60 to suit my batteries. Luckily I can use the 2 x 3S 4700mAh batteries from the Fox glider connected in series to meet the 6S needs of the Draco. Oh, and like the 3M Fox glider I will need to remove the Draco’s wings to get it in the car (bummer)
