RC BOATING SCALE BOATS Boating Scale Boats Electric Sinker Goes Digital Reply To: Sinker Goes Digital
#13941
It’s a lot quicker than using the 360 deg camera but a little longer than if you used something like the Gopro as you need to run it through “Gyroflow” to stabilise it.
The main advantage for it is that you can see where you are going, even in bright sunlight, it’s like using the big bright screen on your Mavic.
Being able to record the footage in 1080 on both the Tx and Rx is a bonus.
It also displays the OSD from the flight controller so I can see how fast I run into you and from which direction.
P.S. It makes it a lot easier to see green things, so I shouldn’t run into the wrong yacht……………………………………Just sayn.
