› GENERAL CHIT CHAT (inc Buy & Sell) › PROP FOR FLOAT PUTT PUTT This topic has 7 replies, 3 voices, and was last updated November 11, 2021 at 6:12 pm by Kermit. Viewing 3 reply threads Author Posts 9 November 2021 at 14:10 #9716 Kermit I NEED A PROP EITHER 6X4 OR 6X5 FOR THE FLOAT PLANE WANTS TO GET OFF THE DAM BUT A BIT MORE PITCH IS REQUIRED I RECON TA 10 November 2021 at 18:11 #9725 Ron Hello Mr Kermit, Will this one do? I can drop it over to Mike for your next fly if you want? Cheers, Ron 11 November 2021 at 16:26 #9729 Kermit THANK YOU RON BUT looks like a 6×6 is required thanks A 6.55 WAS TESTED TODAY SHE WILL LIFT WITH WIND BUT 6×6 should do it for sure 11 November 2021 at 16:39 #9730 Ron No worries Kermit. May I ask, does it have to be 6″ because of the clearance to the fuselage? i.e. a 7″ or 8″ will chop the back off? 11 November 2021 at 18:12 #9731 Kermit yep a 7 does indeed cut into the fuselage 10 November 2021 at 21:25 #9726 Predator I have a 6″ four blade prop with probably a 5 or 6 pitch, might just work for you. 11 November 2021 at 16:24 #9728 Kermit I have just tested a 6.5.5 prop better but now it looks like a 6×6 so dear mike lets have a go with yours OK 10 November 2021 at 22:36 #9727 Kermit GENTLEMEN I THANK YOU if i can see each one its angle relative to the one have that will be great……. let us see the bird fly Author Posts Viewing 3 reply threads You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
