› RC AIRCRAFT › BUILDS › Electric Powered › Firstar EX “Raptor” refit › Reply To: Firstar EX “Raptor” refit
Thanks Ian, it’s a nice project for a rainy day.
I’ve got most of the programming done and had the video feed & OSD up and running on the bench so now its all slowly being fitted into the “Raptor”
The F411-WSE flight controller is installed along with all its wiring & GPS unit. Just 3D printing an antenna mount for the receiver and once that is done I can finish all the internal wiring in the plane & start fine tuning the FC settings.
I do like the fact that the OSD (sent back to the Ground Station or Flight Goggles) is fully programmable in that you can choose how much or how little info is displayed AND where on the screen it is displayed, all very nice & convenient.
Also I believe multiple OSD screens can be set up with different info and these can be selected in flight via the radio.
I’ll have more of a fiddle with that once all the gear is running in the plane. So far all is working out well and I now have all 16 radio channels available via the SBUS link so won’t need to use two receivers any more to allow for the Flaps & FC control channels. The FC also has a switchable output to allow for two cameras to be connected & switchable in flight. Probably won’t worry about that at this stage but would be a bonus on long flights if one camera should fail.
As I was warned by Uncle G, there is way more programming & stuffing around with the iNav controllers compared to the ones we used to use, they were almost just Plug’n’Play especially when compared to this new stuff but hopefully the advantages will outweigh the disadvantages.
We never had a fail of any of the FY-41AP’s except one (that someone whom shall remain a nameless frog) that got rewired incorrectly and had a hole blown in it. I guess only time will tell.
Oh well, back to work.
