› RC AIRCRAFT › FLYING › Flying @ “The Field” › Flying @ the Field 2025 › Friday Flying @ The Field 31-10-2025
- This topic has 14 replies, 4 voices, and was last updated November 11, 2025 at 5:43 pm by
31 October 2025 at 21:20 #20144
After a slow start to the week the weather gradually improved & Wednesday through to Friday were all good fly days.
Fab flew on his lonesome on Wednesday before heading up north for a few days, the rest of us chose Friday.
There was no rain and only light winds till after lunch and even though the temperature showed 17 degrees if felt decidedly cooler with the breeze.
There was a good turn up (9 from memory) and all eager to fly after all the wet & windy days of late.
Rian maidened a little Mustang he purchased from AliEp and it flew exceptionally well. He also got some airtime with his FPV plane but it wasn’t flying too well today.
GG maidened his 3D printed Zero which sounded a bit rough but flew rather fast until it didn’t!! You must be gentle with printed planes GG, they don’t like rough landings.
I piked out maidening my 3D Zero as when compared to the other two it was slightly tail heavy, I’ll fix it this week & be good to go next time we fly. I did however get air time with my ZOHD Altus, Bixler 2 Sport & the ever popular BumbleBee glider. All went well & I got a bit of onboard footage from a couple of flights.
Stephen flew his big IC powered Boomerang as well as a couple of electric planes.
Kermit flew his large Carbon Cub (well tried to) but once again had battery issues so barely got off the ground before breaking it’s beautiful wooden prop.
Ron flew his 3D printed Zero (always flies well) & his Tundra while Gerald showed off his menagerie of 3D printed RC toys before getting some airtime with his Eyas Eagle.
As usual Kermit treated us to his famous “Road Kill Cafe” BBQ for lunch & Stephen’s wife supplied some of her lovely chutney for the BBQ delights, thanks Bev.
Unfortunately I forgot (getting old & CRAFT is kicking in) to take the Sony Handicam today so had to rely on the phone for a bit of video & pics.
I’m sure Kermit will have much better video coverage of the days events.
1 November 2025 at 21:32 #20150
1 November 2025 at 21:40 #20151
Heres the thing I GOT A NOTICE on the computer that said i had a gate crasher with my email account sure enough I had no passwords for emails that also required youtube access so I have made new accounts that has allowed me to get into a new youtube I will try to get my old one back later SORRY ABOUT THAT an i also had to loose a lot of good stuff on the flying vid but such is life ……………………………………………….just sayn
3 November 2025 at 08:49 #20164
Oh-no!!!
3 November 2025 at 08:51 #20165
Great videos and a great day after such a long time.
3 November 2025 at 10:30 #20166
Yes Gadget, it was great to finally get some flying time again, hopefully later this week we can do it all again.
Given that I needed to add a small amount of nose weight to the Zero to correct the CG I opted to reprint the nose-cone in a heavier configuration. I upped the line count from 1 to 4 which gives a far tougher nose-cone & adds an extra 40gm to the weight. The original lightweight nose cones (around 17gm) suffers a lot of damage if landings are less than perfect. Hopefully the stronger one will be better.
Once I print & fit the prop spinner the CG should be close to spot on.
Also programmed a radio knob to quickly adjust the elevator trim in flight so she should be good to go next fly day.
3 November 2025 at 11:25 #20167
Wow! That’s a great idea.
Your zero should be known as Mark II.
I might need an upgrade!
3 November 2025 at 11:27 #20168
Just need to make sure if flies OK then I’ll send you the updated files.
3 November 2025 at 12:33 #20169
DEAR MR PREDATOR SIR. i have about 30 40 spinners plastic /metal if your interested …………………………………………just sayn
3 November 2025 at 17:33 #20171
Thanks for your kind offer Mr Kermit.
Looking for probably a metal one that will fit a 9 x 7 prop & a 3.2mm motor shaft.
I can print one if you don’t have anything suitable.
3 November 2025 at 17:58 #20173
I RECON I WILL ONE like heaps you need to pick the right one I have goton back to my you tube channel by a back door sorta and my email address took a day an most of the night ………………………………………..just sayn
3 November 2025 at 19:20 #20174
3 November 2025 at 19:23 #20175
THIS IS THE ORIGINAL VERSION somewhat extended longer play ……………………………………………………………..just sayn
11 November 2025 at 10:29 #20193
Seems like this is the last flying thread and you are now just a boating club. I got back from Philippines a week ago and have already had 2 full size sails here on a friends trimaran and also drove to Stanley for slope soaring. Here is some sloping footage. I hope you will consider a fly sometime.
11 November 2025 at 17:43 #20196
Nice bit of gliding there Chris.
Hopefully this coming Friday may be OK for our next flying day. Light winds, no rain & around 15 c
