› RC BOATING › SCALE BOATS › Builds › Scale Boats Electric › Cougar Cat › Reply To: Cougar Cat
24 December 2021 at 15:22
#10059
Next Episode – Installing the motors,
3d printed out the motor mounts in PETG and used some 3 mm brass threaded inserts for screwing the motors down.
The mounts were then fixed in place using the 3d printed motor jigs, with epoxy resin thickened with microballons.
The prop shafts were cut to the right lengths. Flats were filed onto both the motor and prop shafts, and everything installed.
The prop shafts lined up perfectly with the motors
The view from the outside,
