RC AIRCRAFT BUILDS Electric Powered Predators First build for 2022 Reply To: Predators First build for 2022
#10134
Still plodding along slowly (no need to rush as the motor wont be here for several weeks) and the left wing is now complete, fitted with servos for ailerons & also flaps, CF brace, etc.
Tomorrow, if not fishing, I’ll start the right one.  It’s a bit of stuffing around as the servo leads need to be significantly lengthened (no room for plug in extensions in the slimline wings) and then tack glued in very precisely so that the wing covers (over the CF braces, wiring etc) will fit flat.
The wings are designed to be removable when completed but hopefully it will fit in the Outback with wings attached. The ASW28 just fitted & the wingspan on that was almost identical.
