› RC AIRCRAFT › BUILDS › Electric Powered › Predators First build for 2022 › Reply To: Predators First build for 2022
28 April 2022 at 19:05
#10951
It’s been a while since any work was done on the TechPod so today it was time to progress a little more towards completion.
The Motor, ESC, iNav system & Rx have now all been fitted & wired up.
It all tested ok so just need to tidy up the wiring and make a few minor changes to the iNav programming and then assembly can be completed & she is ready to test fly.
The RHS of the main pod has been glued to the form-work for rigidity however the LHS will only be attached with reinforcing tape (as suggested by several TechPod owners online) as this makes working on the internals much easier.
