› RC AIRCRAFT › BUILDS › Electric Powered › Predators First build for 2022 › Reply To: Predators First build for 2022
11 May 2022 at 18:22
#11027
On the mini Fox I added 2 inch clear packing tape on the leading edge of the wing from the spar fwd on top and bottom of wing. ts an easy way to stiffen the wing. But it looks like the wing joiner you have is insufficient on the Techpod. Try the tape but if it still flexes like that then you need to beef up the joiner with piano wire or some other means.
