› RC AIRCRAFT › FLYING › Flying @ “The Field” › Flying @ the Field 2022 › Friday Fly-In to finish off the week › Reply To: Friday Fly-In to finish off the week
14 May 2022 at 19:41
#11117
As usual you are correct Chris, it is currently all white inside the dome, hopefully I’ll change it before next flight. At some point I’ll definitely try it with no dome but I’ll need to add exhaust ports as the Pod is pretty well sealed.
Also, I will try and get the camera lens closer to the dome as its around 70mm away at the present. Still needs to be angled down more but after all it’s still a work in progress.
Something different to keep me amused for a short while.
