› RC BOATING › YACHTING › Builds › Predators A Class – Wizzle Wozzle build (a very, very long process) › Reply To: Predators A Class – Wizzle Wozzle build (a very, very long process)
It’s getting close now !!
All the deck fittings have turned up from the Radio Sailing shop and even the new alloy rudder arm arrived today from downtown China.
Just as well I have high ceilings in the Rumpus Room because even so, fully rigged, I only have 50mm clearance from the mast crane to the ceiling.
With a bit of luck & a stiff breeze the deck should go on this weekend (hopefully).
I got some 24 hr epoxy with a 1 hour pot life to epoxy the deck in place, figured it was never going to work out well if I tried with the 5 minute epoxy that I’ve been using to date for the build.
