› RC AIRCRAFT › BUILDS › Flight Controllers & other electronics › SpeedyBee F405-Wing › Reply To: SpeedyBee F405-Wing
Well then, all up you are probably looking at $150.00
F405- Wing FC = $70.00 inc postage
BN-220 GPS = $22.00 inc postage
then you need an XT60 plug & socket
Red & Black silicone wiring (for battery & ESC)
Heatshrink
Compatible Receiver with SBUS & S-Port connections (I use FrSky X8R)
and of course a computer capable of programming the FC. The first one is always a challenge but then they get much easier.
To get the most out of the telemetry you also need a decent RC Radio that can handle LUA scripts, I use a Jumper T16 (which has a large full colour display) but any of the new RadioMaster radios should also be fine & even the older Taranis X9D will do the job but you only get a monochrome telemetry display which is harder to read.
If using FPV both the camera and VTX plug straight into the F405-Wing to provide programmable OSD to you goggles or screen.
