› RC BOATING › YACHTING › Sailing at Puddleduck › Sailing @ Puddleduck 2019 › Puddleduck Vineyard Racing 5.2.19 › Reply To: Puddleduck Vineyard Racing 5.2.19
#2497
HOW DID I fix the duck hunters nose  after lifting the rubber nose protector  the fracture was a clear brake   so i shaped a piece of light thin ply  with two string lines  as two gives a better even pull   water proof adhesive  silicone was applied to the outer wood plug then inserted an pulled evenly to seal the gap   then super glue with mix of baking powder to bond and fill,,,, sand down and finish with body filla  to get the shape back   over all not much material was used  so I don’t think  there will be a weight problem      if I’m wrong  I will rename her  Pb  hunter ……………..Pb symbol for lead   so there ya go not only a fix it lesson  but a lesson on the elements of the periodic table sorted by symbol  hoo rah
