› RC AIRCRAFT › BUILDS › Electric Powered › Sky Climber II – a rebuild story › Reply To: Sky Climber II – a rebuild story
11 November 2019 at 19:36
#3746
As flying @ “The Field” was cancelled today I spent some more time on the Sky Climber rebuild.
Motor has been refitted along with the 40A Turnigy Plush ESC. Reset MAX power (something I usually forget) and all tests OK. I remembered to leave the prop off this time after nearly decapitating the dog when testing Kermits Radian glider (the whole nosecone & motor fell off).
Also designed & 3D printed a new Gimbal & GPS antenna mount.
The pitot tube for the AirSpeed sensor has also been fitted
The pan/tilt gimbal has been repaired & fitted to the new mount
Not far to go now
