› RC AIRCRAFT › BUILDS › Electric Powered › Sky Climber II – a rebuild story › Reply To: Sky Climber II – a rebuild story
14 November 2019 at 20:05
#3755
Its finally starting to look more like a plane now that the wings have been fitted. Also needed to replace the control rods feeding the elevator & rudder as the feed tubes were damaged & blocked with glue. All good now. FPV gear has been tested and its controlling & transmitting as expected, just have the head-tracker on the goggles to test but all else tests OK.
Started on the new livery, the main wings are finished so now only the rudder & tail plane to tart up then a quick tune up of the autopilot & she is good to go.
Oh yes, finally got a name “Prowler” and the callsign VH-FPV
