› RC AIRCRAFT › FLYING › Flying @ “The Field” › Flying @ “The Field” 2020 › Fly-In @ “The Field” 29th January 2020 › Reply To: Fly-In @ “The Field” 29th January 2020
30 January 2020 at 20:44
#4309
In REGARD TO THE JUMPER MK T16 ISSUES I used a patch from the garage using a multiprotocol glue which when used with an external sand paper )(e104) made the patch work and as yet has not released if you use a flash this will have the inability to bind thus making the zamazoon blow up female unusable with out a spectrum DSM from a GITUP HARD powered source I hope this helps
