› RC AIRCRAFT › FLYING › Flying @ “The Field” › Flying @ “The Field” 2020 › Fly-In @ “The Field” 29th January 2020
- This topic has 16 replies, 5 voices, and was last updated February 1, 2020 at 2:38 pm by
29 January 2020 at 17:57 #4300
Another little Fly-In at the field @ Sandford today.
A good turn up with Gerald, Ian, Ricky, Stephen, Moose, Kermit, Ross & me, most sporting multiple planes.
Whilst it was calm early it didn’t take long for the winds (and the temperature to pick up).
Most still flew at least one plane or quad and there were a couple of mishaps to boot.
I think Stephen was the first to come to grief when testing a rebuilt plane on a new radio, seems the motor was a bit under power and a less than pretty landing eventuated.
Moose followed soon after. He managed 3 perfect landings with his Tundra but brought the fourth in way to steep and managed to pop the wing mount off again.
Ian has all sorts of flying things today & whilst his Bixler III flying went off without a hitch he managed to loose (as in never to be seen again) his little (read very little model) twin engined bomber when it got caught in the wind.
Kermit only flew his mini quad today (as we need to do some reprogramming to suit his plane radio) and whilst one flight ended in a bit of searching to see where he landed all was still in one piece & ready to fly again.
Not sure what, if anything , Gerald flew today & the same with Ross but Im sure they will add to the post later.
I was doing further testing with the new Jumper T16 Pro (assisted by Gerald) and after finding that the Spektrum protocols (multi protocol radio) were very limited in range I had to fly very close to home with the MDM-1 Fox glider.
Managed a couple of flights & a bit of video.
Hopefully we can get to the bottom of the Jumper radio issues before our next Fly-In or else I will need to change back to the trusty old DX8 Spektrum & the Taranis X9D and return the Jumper for a refund.
29 January 2020 at 18:57 #4301
Anonymous
My take on our day @ ‘The Field’
29 January 2020 at 18:59 #4302
Anonymous
I can’t get over how dry this place is, roll on winter and hopefully some green grass instead of this..
29 January 2020 at 20:27 #4303
Saw Kermit after he came out after swimming in the Canal last Saturday.
29 January 2020 at 20:58 #4304
Anonymous
Ha ha
29 January 2020 at 21:46 #4305
I WONT LOWER MYSELF TO REPLY TO THE MOOSES COMMENT BECAUSE THE DEAR OL THING IS JUST HANGING IN THERE nice videos fellas anyone see UNCLE G flying today DID anyone see the first two landings of the moooses put putt noooooo how about the last one ” I quote bad angel “….ha ha ha
in the sport of fencing touch’e I think -
30 January 2020 at 14:54 #4306
The Moose with his sharp eye sight did not see Uncle G fly
Sorry uncle G but I can’t tell fibs
30 January 2020 at 17:13 #4308
I tried flapping my arms real fast, but I just couldn’t get off the ground.
30 January 2020 at 15:10 #4307
With regard to the Jumper T16 issues (reported above) when using Spektrum protocols, eagle eyed Gerald found the following post on the Team Black Sheep website.
Radio Firmware – Important!
Both the v2.2.3 and v2.3 versions of JumperTX available for download from the Jumper site support the internal Multiprotocol module, but both have a bug with DSM/Spektrum on the internal module only. The bug has been fixed in the source code but new builds have not been released by Jumper. If you use DSM/Spektrum receivers you must either: Download the latest JumperTX 2.2.3 source from Github and compile it yourself, or Flash the patched JumperTX firmware build (which was built from the Github source and first published here) If you do not do this you will have problems with DSM receivers – inability to bind and/or unstable controls. You have been warned!With that in mind I’ll go back to using the Taranis & the Spektrum radio till the recoded firmware is readily available.
In the meantime I’ll test the radio with Geralds (External) Multi Protocol module and see if its only the internal module at fault or the actual radio coding.
The Fox glider has been refitted with a FRSky X8R receiver and she is good to go again for our next Fly-In. Should have the replacement Bix 2 ready to go as well in the next day or two.
30 January 2020 at 20:44 #4309
In REGARD TO THE JUMPER MK T16 ISSUES I used a patch from the garage using a multiprotocol glue which when used with an external sand paper )(e104) made the patch work and as yet has not released if you use a flash this will have the inability to bind thus making the zamazoon blow up female unusable with out a spectrum DSM from a GITUP HARD powered source I hope this helps
30 January 2020 at 22:16 #4310
Ah my little amphibious mate, if only it was that simple. then perhaps I could go to the field just to fly and you could solve everyone’s problems. 🙂
30 January 2020 at 22:42 #4311
Anonymous
Ketmit quickly log a patent on that fix..
31 January 2020 at 08:43 #4312
Unfortunately The “acme Zamazoom model ” was superseded last week with a new fail safe model with the standard internal gituphard module reports are favourable As a long time user of the previous model ACME will send the upgraded model to me for valuation .AS im still happy with the Zamazoom I only hope that the upgraded model has a safety latch connected to the pressure relief valve as my standard twin cowl model would deflate and go down on me ( but I didn’t worry about that ) I have asked for the new Karzam with the enlarged twin cowlings to be sent to predators house then he can fly it at the field ( somewhere away from us ) and his problems will be solved see Pred i’v already started to solve every ones problems HAPPY MAN HAPPY FLYER don’t thank me dear boy the smile on your face will say it all
31 January 2020 at 13:11 #4313
At last you have found your true calling !!
31 January 2020 at 14:09 #4315
That frog is a pitiful individual
So sad to see He wont be with us for very long ( I have a Plan )
31 January 2020 at 16:31 #4316
Anonymous
Geeeeeeez Kermit I think some people are out to get you keep your head down and under the radar until they go away🤔😑🙄😉😚🤐😴😕
1 February 2020 at 14:38 #4317
SOOOOOO THE MOOOSE HAS A PLAN
A MIGHTY PLAN……. YOU GO GIRL
