RC AIRCRAFT FLYING Flying @ “The Field” Flying @ “The Field” 2020 Fly-In @ “The Field” 24th February 2020 Reply To: Fly-In @ “The Field” 24th February 2020
#4489
Ron, after using the insert link button always click the edit button and make sure the link hasn’t doubled up on the (https//:) bit as this is built into the link setup so sometimes when you cut and paste from another web page you end up with an incorrect link.
I find the easiest is to display the page you want to link to then copy the link from the top address bar, works every time.
Like Here
