› RC AIRCRAFT › FLYING › Flying @ “The Field” › Flying @ “The Field” 2020 › Saturday Fly-In @ the field › Reply To: Saturday Fly-In @ the field
9 August 2020 at 19:00
#5709
The A3 was just small enough to fit on top of the original ESC bracket but this time I’m mounting the ESC on its side under the tray with the stabiliser on top.
All drops in from under the wing so easy to get in and out.
This view is upside down, the esc cable ties onto the tab which drops down through the top plate into where there is plenty of cooling air flow & the stabiliser mounts on the flat top. Rx will go back where it was on the side of the fuselage under the plate.
