› RC AIRCRAFT › FLYING › Flying @ “The Field” › Flying @ The Field 2021 › A nice low wind Holiday Monday fly at the field
- This topic has 12 replies, 6 voices, and was last updated March 9, 2021 at 7:44 pm by
Sinker.
8 March 2021 at 15:18 #7540
Moose picked a good day and turned up with Kermit, Mike, Gerald, Andrew, Ian and myself. Mitch and his grandson came for grandson’s first lesson for a while. There was very little wind and some weak thermals about for a while but the thermals disappeard once the SE wind kicked in around 12. We had a BBQ and continued flying after. I dont think there were any major prangs or issues. Mike’s red Pitts had its motor mount come loose but my LePetit biplane had a much stronger new motor mount.
My new 808 #32 camera was good as a recording camera but when I powered it up with my #16 harness for FPV it had huge lag and then the recording seemed to be at double speed. I have reported it and hopefully a firmware update will fix that. Here is my Eagles footage that I had to reduce speed by 50% post processing:
Here is my V Tail glider which did a lot of thermalling today and a few loops at the end. The front facing cam is my old 808 #16 and the rear facing is the #32. The speed issue seems to be when its externally powered.
Here is my Lepetit Biplane with the #32 which has a wide angle lens.
And Lepetit with old #16
8 March 2021 at 15:49 #7541
Video quality looks quite good, hopefully they will sort out the speed/video lag issues.
8 March 2021 at 15:56 #7542
Our little Green Froggy decided to try a bit of aerobatics in his Eyas Eagle today. The first aerobatic flight was almost accidental but second time around he was definitely putting the Eagle through her paces!!.
Well done Kermit.
It was another perfect day for a fly & BBQ with some mates. No better way to start the week off.
Nice to see Ian back in the air with yet another new Bix 3, must be about #3 or perhaps even #4 but they have all been well flown & well abused but no doubt worth every penny.
8 March 2021 at 20:29 #7545
9 March 2021 at 09:05 #7547
I think I now know why my Razor landed a bit hard!
The remains of my Matek F411-WSE flight controller?
Lucky it happened as I was landing.
9 March 2021 at 17:38 #7557
Rather a bad case of letting the smoke out. Almost impossible to get it all back into the micro containers once its out like that.!!
Almost looks like moisture (or perhaps some creature) got on the board & flashed over ?
I have some LN-10 Flux Remover/Cleaning agent if you want to borrow to clean up the board to try and ascertain what caused the failure, it will remove all that carbon like it was never there.
9 March 2021 at 19:44 #7561
Thanks Mike, I also have some of that cleaner, but I managed to get all the smoke back in!
It’s ready for a test fly.
9 March 2021 at 10:54 #7550
smoke SMOKE YOU FELLAS are having me on like UNCLE G’s secret auto leveeing device on his boat narhh good try you pack of buggars
9 March 2021 at 12:55 #7552
The magic smoke escaped😀😀😀
9 March 2021 at 11:10 #7551
Uncle G any idea what caused the problem
Starting to worry
9 March 2021 at 15:56 #7553
Don’t worry Moose, you have a different flight controller to me.
I still don’t know the cause, have tested all the servos, motor and ESC and all are good, I have fitted a spare flight controller I had and it seems to be working fine now?
9 March 2021 at 16:47 #7556
What a feast of good videos! You covered the field very well, Kermit….great stuff! Our new friend in his Le Petit biplane performed excellently; how can he remain impassive during those pretty extreme aerobatics? Many thanks to all cameramen.
9 March 2021 at 18:29 #7560
My 808 #32 problems have been reported to the developer and should be fixed next firmware update. Looks like I’m the first to want to fpv with it and I will test their firmware
