› RC AIRCRAFT › BUILDS › Gliders › AND YET ANOTHER FLAMIN BIGGER GLIDER
    • #4128
      NOT YET SURE IF THE ELECTRIC DONK HAS ENOUGH OMPFF  TO GET AIRBORNE  so peddle power assist has been installed  The prop is a two bladed plastic thingi with an angle of something the makers have determined will work  The battery I decided to use is a very small buggar  of unknown origin ( no surprises there ) I had intensions of installing a 3d frog pilot but I don’t own a 3d machine but the thought was there ….there is a  camera  to be installed  the latest super 8 or was in 1967  (in colour) film  a power cable of unknown length will accompany the camera and aircraft as it doesn’t have a inbuilt battery   ( may restrict flight height )  this once off experimental ultra light  aircraft if production is continued  will come in several colors  white /black/ black&white    this aircraft will be produced by TOP GUN AIRCRAFT INDUSTRIES  if you want more information on this sturdy little Gower contact   Kermit la frog  (managing director  )
    • #4132
      All you need is a good downhill run & I’m sure it will get airborne.
