› RC AIRCRAFT › BUILDS › Electric Powered › Foxbat Ultralite fitout
    • #4262
      The little Foxbat Ultralite is another of Graeme C’s scratch built aircraft that I acquired a little while ago.
      I have relocated the ESC from under the dashboard to inside the engine cowling. This should result in better ESC cooling and it makes the battery much easier to install.
      I have also installed a pin lock system on the wings & wing struts as the tiny screws were a pain to install & remove
      The wing strut lock pins are secured with silicone cooling tube
      while the Wing spar lock pin is secured behind a small screw.
      An A3 stabiliser has temporarily been installed till I found out how the little Ultralite handles & this is coupled to a Lemon RX (why-because I had one) and programmed to the Spektrum protocol on the new Jumper T16 Pro radio.
      A couple of Foxbat logo’s have been added to tart her up a bit and she should be ready to take to the air on our next flying day.
      Hopefully it will fly as well as the real ones.
      The Real VH-FBX @ Avalon Airfield Victoria 2015
    • #4263
      Graeme sure can build beautiful aircraft and now we will be able to see this magnificent putt putt in the air  thanks to you predator  well done
