› RC AIRCRAFT › BUILDS › Electric Powered › Islander 2A twin engine RC Plane
    • #4023
      I recently acquired a scratch build Par Avion Islander 2A twin engine RC plane from the builder Graeme C who has downsized his accommodation and was finding difficulty storing all his brilliant builds.
      The Islander only needed some very minor repairs but at the same time I took the opportunity to install an FY-41AP Auto Pilot/Stabiliser with GPS, Circle Mode & RTH including RTH in failsafe mode.
      Also converted the plane to counter rotating engines and fitted 1 x 8×6 cw standard electric prop and 1 x 8×6 ccw pusher electric prop. This setup negates and prop torque and makes for smoother take-offs and flights.
      The plane also has switchable FAA navigation lights, multi position flaps & a steerable nose wheel.
      Everything seems to be functioning correctly so all we need now is some decent flying weather to test it out.
      Now the Islander is finished & ready to fly its time to start on the Foxbat Ultra lite that was acquired at the same time.
      The strip down & rebuild of the Foxbat A22LS is under way
    • #4025
      Well then, apart from installing the removable clears the Foxbat is finished, including radio programming & should be OK to fly.
