› RC AIRCRAFT › BUILDS › Electric Powered › Pitts Special biplane – upgrade
    • #5768
      After the less than successful first attempt at flying the recently acquired 800mm Pitts Special biplane, mainly due to lack of power, I have done a couple of upgrades.
      The landing gear failed on the first attempt (after all our flying field [sheep paddock] is a tad rough) as did the bottom of the fuselage holding the landing gear attached.
      The floor area has now been replaced with a slightly heavier grade of modelling ply and the wheel struts & wheels (larger diameter & width) replaced also. Hopefully strong enough now.
      Now for the power issue.
      Motor is an RC Smart EVO 1084kv outrunner swinging a 2 blade prop.
      Original      –   8 x 4 prop – Output was 100W @ 8.4A WOT
      Upgrade 1  –   8 x 6 prop – Output was 120W @ 10.oA WOT ~ Not much improvement
      Upgrade 2 – 9.5 x 6 prop – Output was 140W @ 12.0A WOT ~ Slightly better
      Upgrade 3 -11 x 7.5 prop – Output was 190W @ 17.0A WOT ~ Much better – almost double the output.
      Bottom is original prop, top is current prop
      Upgrade 3 is what I will be trialling but if its too aggressive I’ll get a 10 x 6 & try that.
      Research has shown that the 850mm Eflite brand EPO foam Pitts Special, using an 880kw motor & 40A ESC (on 3S or 4S) spins a 11 x 7 prop so my selection should be in the ballpark.
      Added a bit of Pitts branding (because I can) & she is good to go once the weather improved (hopefully)
    • #5769
      CG should be about 65mm back from top LE. Wednesday forecast looks ok.
      • #5770
        Yes, may be OK, light rain after lunch only & very light winds.
        Could be a goer.
