› RC BOATING › YACHTING › Sailing at Puddleduck › Sailing @ Puddleduck 2021 › Puddleduck Vineyard Racing 29-06-2021
- This topic has 7 replies, 3 voices, and was last updated June 29, 2021 at 7:16 pm by
29 June 2021 at 15:19 #8491
DF95 Racing today @ the Duck
Information kindly supplied by the Admiral
6 x DF95’s
1 x IOM #196 (Admiral)
1 x DF65 #no number (David) does not show up in the scoring.
Cool temps and hot racing in a perfect winters day.
Excellent breezes out of N/E shifting to N as the morning progressed.
Phil was best DF95 on the day but racing was very close among all participants throughout the morning.
Admiral brought the Royal Barge (IOM #196) for a bit of a play and tune up.
David brought his DF65 along for a bit of practice.
Excellent day out.
Cheers
Col
From the supplied scoresheet I’m not sure if handicaps were applied today or not.
First Place on 23 points was #196 Col – IOM (well fancy that), Second Place on 26 points was #261 Phil T – DF95, Third place on 30 points(on count back) was #58 Stuart – DF95 closely followed by #37 Trouty – DF95 , also on 30 points.
Both Stuart & Trouty had 2 x 1st place, 1 x 2nd place, 1 x 3rd place then Stuart had a 4th while Trouty had a 5th.
29 June 2021 at 15:56 #8494
WELL I GUESS A FEW MORE like this from the cooks assistant an he may regain his rank
29 June 2021 at 16:48 #8496
The Admiral began with a minute handicap, ending with 1m 30sec. Both Phil, Trouty and Stuart ended the day with 20 second handicaps. Fabulous sailing in perfect conditions and enjoyed by all.
29 June 2021 at 17:12 #8497
Either your numbers are incorrect or there was a lot of skulduggery going on with the handicaps.
I just redid the score sheet with handicaps based on the supplied results & they are vastly different from above.
29 June 2021 at 17:17 #8498
Most likely that has occurred because there was awarded a 10 seconds time penalty for first place and 5 for second due to the small number of competitors.
29 June 2021 at 17:51 #8499
Gee, changing the rules again, anyone would think I had a Crystal Ball.
Just as well we are all friends & not racing for Sheep Stations.
29 June 2021 at 18:52 #8500
Can’t make it too easy for you! 😉
29 June 2021 at 19:16 #8501
QUESTION how much is the sheep station
