› RC AIRCRAFT › BUILDS › Electric Powered › Question regarding propeller thrust… Tagged: Builds Electric Propeller Thrust This topic has 5 replies, 3 voices, and was last updated June 27, 2022 at 10:28 am by Predator. Viewing 3 reply threads Author Posts 26 June 2022 at 13:58 #11444 Gadget I’m wondering if this method of measuring propeller thrust is good enough to get an idea on plane performance? The plane weighs 600g and then after zeroing the luggage scale, full throttle gives me 1,000g of down thrust. I’m thinking the performace of the plane should be pretty good? 26 June 2022 at 14:54 #11446 Stephen From memory, with my luggage scales tied to the tail and the bench leg I get about 900kgs for the red plane. I think that flies ok 🤔 26 June 2022 at 15:19 #11447 Predator I think you may have a “k” too many Stephen, with 900kg of thrust you would be dragging the bench across the workshop. Good info here Ron https://joyplanes.com/en/power-to-weight-ratio-rc-aircraft/ 26 June 2022 at 17:07 #11448 Gadget Wow! 900kgs. That’s a lot of thrust 😂 Thanks Mike. I’ll have a read of that. 26 June 2022 at 19:50 #11449 Stephen Mmm, maybe just grams 😁😁😁😁 27 June 2022 at 10:28 #11452 Predator grams – That sounds more like it. Author Posts Viewing 3 reply threads You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
