› RC AIRCRAFT › FLYING › Flying @ “The Field” › Flying @ “The Field” 2020 › Saturday Fly-In @ the field
- This topic has 18 replies, 6 voices, and was last updated August 9, 2020 at 7:00 pm by
8 August 2020 at 16:05 #5690
The day started off slightly chilly and the wind was a tad stronger than predicted but it didn’t stop anyone from having a fly.
Our numbers were boosted a bit today with Ron, Neil & Connor joining in but we were missing regulars Ross (Bad Angel), Ricky & Tristin.
A couple of minor mishaps today but overall a fairly good day by all.
8 August 2020 at 17:33 #5691
Here is the gun cam footage from my Esky Eagles
And here is the Skipper XL
8 August 2020 at 18:16 #5693
Nice, I’m still editing so may be a little while.
Did you get any decent footage of the biplane flight?
9 August 2020 at 16:56 #5702
Hi Chris,
This was this only way I could work out how to send you links.
I found the following links to the glider.
https://www.aliexpress.com/item/4000090854844.html
https://www.aliexpress.com/item/4000833201413.html
This is the Aliexpress store:
https://www.aliexpress.com/store/4775022
See if they work for you.
Cheers,
Ron.
8 August 2020 at 18:13 #5692
Hat cam footage of my Tundra.
8 August 2020 at 18:20 #5694
Good one Ron, the Tundra’s do fly nicely.
It’s a pity we couldn’t get some better range out of the Hat Cams.
8 August 2020 at 19:57 #5695
Here’s my video of the day.
8 August 2020 at 20:35 #5697
You definitely fly much less aggressively than I do, probably why your plane is still in one piece & mine isn’t.
Ah well, nothing a bit of glue won’t fix.
8 August 2020 at 20:07 #5696
Well men looks like another great day good to see the videos as they are put up.
By the way Kermit I was surprised to see so much snow had fallen on you to day when no one else was covered in it but that’s a frogs life.
8 August 2020 at 20:58 #5698
Nice footage of the aerie of eyas eagles.
8 August 2020 at 22:28 #5699
9 August 2020 at 17:38 #5704
Given the gear you are trying to work with Kermit my man It was another top video with lots of great content. Well done.
8 August 2020 at 23:09 #5700
SOOOO SORRY ABOUT MY VIDEO the camera thingi was set on art god knows why hence over colored green and the lens going in out of focus what a buggar up but…… such is life now to ol smarty bum Moose MY hair color is from fear you try livin with the dragon an now a special thank you to our top best weather man uncle G NOT ONLY A SUPERB FLYER but now top weather man what cant he do LOVED hoppys gun sights and machine guns an the best grouping of aircraft in a video yet very nicely done But over all SECOND place goes to ………wait for it………UNCLE G .for flying at the field .FIRST goes to around the field PREDATOR for over all content if you wish to dispute this selection post your comments only to pleased to dismiss them an finally BAD ANGEL its not true the rumor going around that bad angel has lost the edge …the nerve ..the will to fly Im sure its no more than a broken finger nail GOD BLESS OUR GOD KING PRESIDENT IAN
9 August 2020 at 13:52 #5701
ALL RIGHT YOU SMARTY BUMS WHO PUT THE SHEEPS BONE IN MY TUCKA BOX … AY WHO WAS IT
well I thank you because as you know I’m on a diet an that bone went to make a nice yummy SOUP SO THANK YOU
9 August 2020 at 17:48 #5706
My Li’l Eagle repairs are well under way after its “Down is up & Up is expensive” episode at the end of flying yesterday.
The timber gear tray was trashed so I designed & printed a new one which seemed easier than stuffing around repairing the old one.
Fits just like a finger in a bum.
Now working on the bracket to hold the ESC and the A3-V2 stabiliser.
With the new gear tray installed the central body has now been glued back together.
The damaged aileron has also been repaired
I’ll leave them overnight for the glue to dry properly then tomorrow repair the battery tray & front wheel mount and she will be all good to fly inverted once again.
9 August 2020 at 18:22 #5708
Mike I moved the ESC to under the tray and removed the small tray which was above it and mounted the stabiliser there.
9 August 2020 at 19:00 #5709
The A3 was just small enough to fit on top of the original ESC bracket but this time I’m mounting the ESC on its side under the tray with the stabiliser on top.
All drops in from under the wing so easy to get in and out.
This view is upside down, the esc cable ties onto the tab which drops down through the top plate into where there is plenty of cooling air flow & the stabiliser mounts on the flat top. Rx will go back where it was on the side of the fuselage under the plate.
