RC AIRCRAFT BUILDS 3D Printing RC Planes Sinkers 3D Printed Albatross
Viewing 11 reply threads
    • #13965
      The Mercedes 6 cylinder motor is ready to be installed in the Albatros.
    • #13967
      Wow! That looks great Gerald.
    • #13990
      All parts have been printed.
      Motor installed, fuselage and wings etc all have been sprayed with a clearcoat ready for the colour.
      I tried a different method to glue the LW PLA parts this time as recommended in the instructions: –
      I used these small bottles, and it worked really well. A lot easier than putting on the glue and then bringing the parts together.
      Rudder, elevator and axle cover have been painted in red, waiting to dry.
    • #13993
      Prefit & then glue is a good idea, amazing what you find when you read the supplied notes. Certainly should be easier as they lock together quite well.
      What clearcoat do you use before painting?
      I painted straight onto the printed parts but it’s a bit hit & miss. Looks ok from a few feet away though !!
      • #13996
        I used this one, It’s an Acrylic like the “Little Squirts” I’m using for the colours.
        Tried it today and didn’t get any adverse reactions from the topcoat.
        The main reason to use it was because the fuselage has different colours, and I didn’t want the edges to bleed.
    • #13998
      No problems, thanks Gerald. I’ll grab some tomorrow before I start painting the stripes on the Wolf.
    • #14058
      Painting almost complete.
      Wings primed with a clear coat and some shading applied.
      Wings painted,
      The shading turned out a bit darker than I was hoping for.
      The fuselage, (It’s not that bright in real life)
    • #14059
      Baron Von Whatshisname is getting nervous! (He has a tight hold of the stick)
      Primed and shaded,
      Ready to fly? (Or die)
      Just waiting for some bits to arrive and then it just needs assembling, and the electronics installed.
    • #14060
      Tis coming along very nicely.
      • #14061
        Slow and steady, Mike.
        • #14062
          Likewise with my G01 Wolf, just plodding along installing the electronics.
    • #14151
      Getting closer.
      All servo’s installed, machine guns loaded, just waiting on the prop so I can install the motor and electronics in their correct places.
    • #14155
      Looks very nice Gerald. You have done a great job with that 👍
    • #20085
      Wow has this flown yet? Not seeing much footage lately but I will be Hobart from Nov 3rd.
    • #20089
      Of course it’s flown – once
      The field is a bit rough for its landing gear.
