› RC AIRCRAFT › BUILDS › Electric Powered › Super Chipmunk
Viewing 6 reply threads
    • #9596
      This was my other birthday present, this time from Kermit. Thanks my little green friend.
      It’s all built so just need to check everything over & sort out the electrics and it should be good to go.
      The Super Chipmunk is quite a large plane with a fibreglass fuselage & built up wings.
      Wingspan 1600mm
      Fuselage 1250mm
      Not sure what the motor & ESC are but it’s spinning a 14 x 7 prop.
      All servo’s are standard (full size) variety.
    • #9597
      very nice Mike
      Looks a rapid little beast
      waiting for parts is a bummer
      i am watching next Wednesday for a fly
    • #9598
      I had 2 flights in Chipmunks when 16 as an air cadet. Its the best handling plane ever; turned on rails. I would love to have a model Chipmunk (not Super Chipmunk).
    • #9607
      The Super Chipmunk is finished & ready to fly.
      The Motor is a Turnigy Aerodrive C4260-500
      and the ESC is an 80A Flyermate capable of using 2S to 7S LiPos
      Some online info suggests the plane needs a 5S or even a 6S LiPo but other posts suggest a 4S is fine.
      The plane has a purpose build battery hole in the underside and given that a 4S 4000mAh (ex Grand Tundra) is a perfect fit and gives a near perfect COG that is what I’ll try.
      The motor has been lubricated & all fixings locktite’d, the wiring tidied up with XT60 plugs instead of the old Deans connectors and a new receiver & Hobby Eagle A3-V2 stabiliser installed & programmed.
      Hopefully Tuesday or Wednesday will be good to fly so won’t need to wait long to try it out.
    • #9609
      Looking Great
      How did you find the engine mount I have Order the one
      wednesday looking the better
      • #9612
        Moose, one thing I found online was that large slow powerful motors really need metal engine mounts. Prolonged running generates significant heat & timber or plastic mounts tend to fail when they get hot.
        The Chipmunk has a full metal mount all the way from the firewall to the motor. One section bolts to the firewall and the front section that holds the motor is adjustable via 4 bolts (two each side) so the up/down and left/right angle of the motor is easily adjustable.
        If you cant find one on line then I’m sure one could easily be made with some aluminium plate.
        Here is a link to one similar to the Chipmunk, for the price its not worth making one.
        This one is by far the cheapest (from AliExpress) but eBay & Banggood also stock them, just a lot dearer.
    • #9615
      Thanks Mike
      I was just curious To see what you thought about them Mine should arrive on Wednesday I ordered it about 3 weeks ago
    • #9628
      Well the first flight of the Super Chipmunk did not go as well as it should. The plane was way underpowered with the 14 x 7 prop only pulling 320W @ 20A.
      I have replaced it with the 17 x 8 prop from the Grand Tundra and it is now pulling 640W @ 44A so that may well be enough.  Both the Motor & ESC are overrated with the online info suggesting a 400kV motor & 60A esc are all that is needed.
      No doubt next flying day will see.
