› RC AIRCRAFT › BUILDS › Gliders › The Bigger the Better
- This topic has 24 replies, 6 voices, and was last updated January 19, 2022 at 8:10 pm by
Gadget.
27 April 2021 at 15:54 #7926
To paraphrase our little amphibious friend Mr Kermit “YET ANOTHER FLAMIN BIGGER GLIDER” and this one is a doozie.
It’s on order (I got a price I couldn’t refuse – delivered Express from a Hobby Shop in NSW) so it shouldn’t be too long arriving however the required “BIG” battery (5000mAh – 6S) is on its way from Down-town China and could be up to 4 weeks.
If it flies as well as I hope I think I will probably sell the 2.6m ASW 28 and maybe the 2.3m Fox to make room for it.
Anyway here is a video to tempt you in the meantime.
28 April 2021 at 10:08 #7934
Wow, what a machine 👌
28 April 2021 at 15:12 #7936
Very nice Pred, look forward to the videos. You seem to suffer from my disease, its just not fair when they hang those prices in front of you.
28 April 2021 at 20:11 #7939
Ah well, you only live once & unfortunately none of us are getting any younger so I have decided to sell the planes I rarely (or no longer) use & buy the ones I want to fly.
Not quite sure how I’m going to get it in the wagon yet. Methinks it will need to be dismantled every time for transport.
28 April 2021 at 22:48 #7942
My problem apart from being a sucker for a good price (well in my eyes) is I dont sell anything, against my nature. I have a number of yacht kits still sealed in their boxes which I was going to do builds on SS but that did not happen and I lost all enthusiasm. Should get my mind into selling them as they will never get built. just a case of testing the waters I guess.
1 May 2021 at 20:09 #7967
I don’t particularly like selling things either but as I’m no longer working there is not as much disposable income as there once was. Plus I’m running out of storage room so selling a few of the rarely used items solves two problems and allows me to keep experimenting with new builds etc.
Works for me !
I find that while some things will sell on Gumtree (usually in the local area), RC Trader is the best place to sell both planes and boats but you need to be prepared to ship them. Easy if you still have them in the original boxes. You could be sitting on a goldmine Tug !!
5 May 2021 at 14:00 #7995
Well well a very large box has arrived.
5 May 2021 at 14:59 #7997
Better watch out Pred it could be a FROG clone.
5 May 2021 at 21:40 #8000
We already have one of those, showed up at the field again today flying “Fly Baby”
Spitting Image, don’t you think !!
6 May 2021 at 16:24 #8002
I had a little bit of time to spare today so started sorting out the new FMS MDM-1 Fox 3metre glider.
Just enough room to get around it in the Rumpus Room
It does all pack very nicely back in the supplied box but requires breaking down into its 5 parts to do so. I really don’t like pulling things apart for no good reason so I don’t like that option if there is any other way.
This is the difference in size of the canopies between the 2.32m Fox & the 3m Fox
Before too much assembly (there are only 5 parts anyway, fuselage, tail/rudder assembly, tailplane & two wings) I needed to work out the best way to transport it.
It will fit in bits and if I make some sort of cradle to support it all that needs to be removed are the main wings, the complete tail assembly can be left in place as there is enough length & height in the Outback to fit it (just).
Anyway the Rx & ZOHD Kopilot have been programmed along with the radio & now just waiting for the 3D printer to spit out a small stand for mounting the electronics on. Down in the bottom of the fuselage is too hard to work on.
6 May 2021 at 16:41 #8003
That’s huge! Are you sure there’s going to be enough room left in the sky for other planes?
6 May 2021 at 17:41 #8007
The wingspan is about the same as Andrew’s big glider, it’s just that the fuselage is so much bigger.
6 May 2021 at 17:57 #8008
You are going to need a bigger house.
6 May 2021 at 19:16 #8009
6 May 2021 at 19:28 #8010
Now that’s what I need, all the toys would fit in that along with Kamp Kermit !!
9 May 2021 at 17:00 #8047
The 3m Fox is ready for her Maiden Flight, just need a decent day now to try it out.
Got the RunCam 2 installed temporarily inside the canopy in place of the pilot for (hopefully) a true pilots eye view.
There is a bit of distortion from the canopy moulding so I’ll try it for one flight before stuffing round with a Pan/Tilt mount & remote control for it.
If the video is too distorted I’ll just go back to a wing mount camera.
13 May 2021 at 18:16 #8077
I now own the 2.3m fox and it’s ready to fly with vario etc setup. Here is a good wheel option.
13 May 2021 at 19:54 #8078
But our runway a bit rougher than that one
14 May 2021 at 13:47 #8079
First trial fit of the glider in the partially completed launch dolly.
Now to fit the spacers to hold the floor in place & cut and fit the axles & all 4 wheels.
15 May 2021 at 16:37 #8086
Finally (apart from a lick of paint & a few lightening holes – if needed) the Fox Dolly Trolley is finished & ready for our next fly day.
With the addition of a front & rear foam block the trolley also doubles as a carrier for transporting the assembled fox (with main wings removed) . Just enough length to fit in the Outback without having to move the front seat from its normal position.
Bring on some flying weather but in the meantime I’ll install the variometer, removed from the old Fox 2.3, & connect the flight battery telemetery.
16 May 2021 at 08:20 #8091
No more hand launching for you. It looks spectacular, just like the plane!
25 May 2021 at 16:44 #8147
Dolly Trolley – take two, raised the angle slightly & added a couple of wing stop posts.
The problem seems to be with the original design that the bumpy ground dislodges the glider from the dolly trolley before it gets up to speed. I’m sure it would have worked fine on a paved or mown runway but not so in our sheep paddock.
Hopefully this simple mod will fix the problem.
May need to fiddle the post heights a bit but will just have to wait till our next Fly Day to find out.
18 January 2022 at 16:16 #10214
After unceremoniously removing the tail (twice on different flying days) I thought that perhaps the “Dolly Trolley” needed a mod or two.
During the last mishap my rear mounted camera captured the problem, it was caused by me using far too much up elevator to get airborne rather than launching into the wind (which is not always easy where we are) and allowing the Fox to get airborne by itself.
Anyway, if I now forget and crank on too much up elevator the auto lift function built into the “Dolly Trolley” should now take care of it. May even try it this coming Thursday.
19 January 2022 at 09:18 #10217
Looks like that should work really well 🤞
19 January 2022 at 20:10 #10219
Well done Mike.
That design look really good.
